Normal Topic shape & tablenode attachnode anneallayout prob (Read 1796 times)
BidMaestro
to learn is to live
May 10th, 2008 at 4:07am
Hi Guys
I am having a small problem with a tablenode attached to a shapenode. When you the run a layout (AnnealLayout) it separates the attachednode from the shapenode.
If you use your Telephony VB example and add a simple button with teh following code and run it you will see what I mean; select the Input Sequence icon with atached tabel to drop onto the diagram
Dim layout As MindFusion.Diagramming.Layout.AnnealLayout = New MindFusion.Diagramming.Layout.AnnealLayout
       layout.Arrange(view.Diagram)
How can I stop the tablenode from being detached from the shapenode after a layout operation?
regards
Doug
Re: shape & tablenode attachnode anneallayout
Reply #1 - May 12th, 2008 at 9:46am
Enable either the table's IgnoreLayout property, or the layout's KeepGroupLayout property. Check the [url=http://mindfusion.eu/onlinehelp/flowchartnet/index.htm?P_MindFusion_Diagramming_Layout_LayeredLayout_KeepGroupLayout_0.htm]KeepGroupLayout[/url] help topic for an explanation what is the difference between the two methods.
BidMaestro
to learn is to live
Reply #2 - May 12th, 2008 at 10:52am
As always your advice is perfect; the ignorelayout property worked a treat.
The KeepGroupLayout worked better as the tablenode that I attached had quite a few rows and this property kept all the nodes nicely spaced after the layout.
Thank you
Doug
