Very Hot Topic (More than 25 Replies) PDFExporter Memory Leak (Read 15625 times)
mclellan
May 12th, 2008 at 8:45pm
In my code I loop through a database creating flowcharts into Visio and PDF format.
After creating roughly 80 pdf's I am running into out of memory issues. If I just create Visio's I have no issues.
When the last visio (before it dies) is exported all of the nodes are grayed out - not sure if that helps!
Let me know what I can do to help you with this.
Barry
mclellan
Re: PDFExporter Memory Leak
Reply #1 - May 12th, 2008 at 8:47pm
Sorry, mis-typed there!
Should be, when the last PDF dies! Visio Exporting is working without issues.
Barry
Reply #2 - May 13th, 2008 at 2:36pm
Is there any exception thrown after the 80th PDF, and could you paste the stack-trace here? Are you using the same PdfExporter instance to export all files?
mclellan
Reply #3 - May 13th, 2008 at 4:12pm
Yup, after the 80th there is an exception thrown, see stack dump below. As well, I am using the same pdfexporter for all exports.
   at System.Drawing.Graphics.GetHdc()
   at MindFusion.Drawing.GdiGraphics.GetHdc()
   at MindFusion.Pdf.PdfGraphics.GetHdc()
   at MindFusion.Pdf.PdfFont.xed0095cff33220da(Font x26094932cf7a9139)
   at MindFusion.Pdf.PdfFont..ctor(Font font, PdfPage _page)
   at MindFusion.Pdf.PdfPage.AddFont(Font font)
   at MindFusion.Pdf.PdfText..ctor(PdfPage _page, Font font, Brush _brush, String s, StringFormat format, RectangleF _layoutRect)
   at MindFusion.Pdf.PdfGraphics.DrawString(String s, Font font, Brush brush, RectangleF layoutRectangle, StringFormat format)
   at MindFusion.Diagramming.ShapeNode.xeda13f64d938197c(IGraphics x41347a961b838962, RenderOptions xdfde339da46db651)
   at MindFusion.Diagramming.ShapeNode.xc79d59e9288101bd(IGraphics x41347a961b838962, RectangleF xa6236fc5cd405c4e, Boolean x2f9dabff87b2168b, Brush xb45de92d01a0ec1f, Pen x9c79b5ad7b769b12, RenderOptions xdfde339da46db651)
   at MindFusion.Diagramming.ShapeNode.Draw(IGraphics graphics, RenderOptions options)
   at MindFusion.Diagramming.Diagram.x83e1efc9aa69ada9(IGraphics x41347a961b838962, DiagramItem xccb63ca5f63dc470, Boolean x9c41bb4d9b3b314f)
   at MindFusion.Diagramming.Diagram.x679ae26de3befa07(IGraphics x41347a961b838962, RectangleF xd0772cd9ac472b96, Boolean x979174172ae18db3)
   at MindFusion.Diagramming.Diagram.Draw(IGraphics graphics, RenderOptions options, RectangleF clipRect, Boolean noModifiedItems)
   at MindFusion.Diagramming.Export.PdfExporter.Export(Diagram diagram, String filePath)
   at VectorFlow.frmFlow.LoadDiagram() in D:\FlowChart\Flow\frmFlow.vb:line 741
Hope this helps!
Barry
Reply #4 - May 14th, 2008 at 2:49pm
Hi Barry,
Look for updated assemblies in the private messages page (there is a link to it at the top of the forum page). Please try exporting to PDF with them and let me know if there is any improvement.
mclellan
Reply #5 - May 14th, 2008 at 3:16pm
I copied this into my MindFusion directory (after backing up the original... and I have the following compiler errors when I attemp to run it:
Error: The dependency 'MindFusion.Pdf, Version=1.0.2901.27726, Culture=neutral, PublicKeyToken=0b3a610038a66854' in project 'VectorFlow' cannot be copied to the run directory because it would conflict with dependency 'MindFusion.Pdf, Version=1.0.3056.29537, Culture=neutral, PublicKeyToken=0b3a610038a66854'.
Error: The dependency 'MindFusion.Pdf, Version=1.0.3056.29537, Culture=neutral, PublicKeyToken=0b3a610038a66854' in project 'VectorFlow' cannot be copied to the run directory because it would conflict with dependency 'MindFusion.Pdf, Version=1.0.2901.27726, Culture=neutral, PublicKeyToken=0b3a610038a66854'.
mclellan
Reply #6 - May 14th, 2008 at 3:41pm
Ignore that last post, I didn't add a reference to Mindfusion.pdf (I don't think I needed that before)!
Here is my error now: (happens right away)
   at System.Drawing.Graphics.FromImage(Image image)
   at MindFusion.Diagramming.Diagram.CreateMeasureGraphics()
   at MindFusion.Diagramming.Diagram.x8bf95fac764336fc()
   at VectorFlow.frmFlow.LoadDiagram() in D:\Flowchart\frmFlow.vb:line 741
Once done, I see another message box that says: Invalid Parameter Used
Barry
mclellan
Reply #7 - May 14th, 2008 at 3:43pm
Traced through the code again... seems to happen on the second export in the loop.
Barry
Reply #8 - May 14th, 2008 at 5:04pm
Could you call SaveToXml and email the diagram file to support@mindfusion.eu?
mclellan
Reply #9 - May 14th, 2008 at 5:06pm
Sure, do you want me to set it back to the old version, or the current one?
Barry
Reply #10 - May 14th, 2008 at 5:26pm
Doesn't matter, the XML file should be the same. Could you also post your PdfExporter initialization code?
mclellan
Reply #11 - May 14th, 2008 at 5:42pm
Sure, I didn't think there was much code to initialize this.
I have:
    Dim pdfExp As New MindFusion.Diagramming.Export.PdfExporter
... at the start of the program
Then I call this for each loop.
pdfExp.Export(VectorView.Diagram, OutputDir & "\Flowchart " & Number & ".pdf")
Reply #12 - May 14th, 2008 at 5:45pm
Does it also happen if you move the pdfExp declaration inside the loop - so that there is a new PdfExporter instance used for each exported file?
mclellan
Reply #13 - May 14th, 2008 at 5:59pm
Just tried it, new version still dies after the first export, the old version dies at 80 pdf exports.
Top of each loop
   Declared PDF Export
   Exported
  Set PDFExport = Nothing
  Back to top of loop
Barry
Reply #14 - May 15th, 2008 at 11:00am
Unfortunately I could not reproduce that. Could you also post the initialization code for your Diagram object? If you are doing any custom drawing, please also post the Draw-event handlers code.
