Normal Topic NullReferenceException with OriginIndex (Read 1853 times)
cspurling
May 1st, 2008 at 1:34am
Not a high priority bug but probably still needs to be fixed.
When creating a link between two table nodes, if you set the OriginIndex before you assign a destination node to the link a NullReferenceException is thrown.
The code below throws the exception:
DiagramLink lnk1 = new DiagramLink(diagram1);
lnk1.Origin = nde1;
lnk1.OriginIndex = 0;  // exception thrown here
lnk1.Destination = nde2;
lnk1.DestinationIndex = 1;
diagram1.Links.Add(lnk1);
You need to assign the destination node first:
lnk1.Origin = nde1;
Re: NullReferenceException with OriginIndex
Reply #1 - May 1st, 2008 at 7:12am
Thank you for your feedback, we'll surely fix this in the next version.
