Very Hot Topic (More than 25 Replies) PDFExporter Memory Leak (Read 15637 times)
mclellan
Re: PDFExporter Memory Leak
Reply #15 - May 15th, 2008 at 1:20pm
Can I send you the code directly?
It's not very complicated, and I am not doing anything custom.
Barry
Reply #16 - May 15th, 2008 at 1:52pm
Of course, please send us the code.
Reply #17 - May 15th, 2008 at 2:33pm
It's not a good idea to call VectorDiagram.Dispose() and then continue using the same diagram object. Please remove that line and try the PDF export again.
mclellan
Reply #18 - May 15th, 2008 at 2:54pm
I removed that line of code... same error occurs.
Barry
Reply #19 - May 15th, 2008 at 3:09pm
Which same error - the one after the 80th export or on the 2nd one? That latter exception can happen only if you are using a disposed diagram, so in that case check if there isn't another Dispose() call done from somewhere. I see you are running the application from the command line - make sure you aren't running an old version.
mclellan
Reply #20 - May 15th, 2008 at 3:53pm
Hi Stoyan!
Success!
On the older version, I removed any reference to a dispose and it still died at 80.
However, on the latest version you sent me, it is now working after I removed the dispose line you suggested.
So far I have exported 192 pdf's and Visio's.
Should I continue to use this build for testing and deployment?
Thanks!
Barry
Reply #21 - May 15th, 2008 at 4:28pm
great news 8) yes, use the new build, it should be quite stable.
mclellan
Reply #22 - May 15th, 2008 at 5:52pm
Aaah, sorry, jumped the gun a bit there although much much better!
I managed to pull out 781 pdf's before it crashed.
   at System.IO.Path.nGetFullPathHelper(String path, Char[] invalidPathChars, Char[] whitespaceChars, Char directorySeparator, Char altDirectorySeparator, Char volumeSeparator, Boolean fullCheck, String& newPath)
   at System.IO.Path.GetFullPathInternal(String path)
   at System.IO.Path.GetFullPath(String path)
   at MindFusion.Pdf.PdfDocument.Save(String fileName)
   at MindFusion.Pdf.PdfGraphics.Dispose()
   at MindFusion.Diagramming.Export.PdfExporter.Export(Diagram diagram, String filePath)
   at VectorFlow.frmFlow.LoadDiagram() in D:\FlowChart\frmFlow.vb:line 742
I think we are getting much closer now though!!
Barry
Reply #23 - May 15th, 2008 at 6:33pm
Now that looks like some kind of a file system error. What is the name of the exception you are getting?
mclellan
Reply #24 - May 15th, 2008 at 6:44pm
Sorry Stoyan,
We made it past the pdfexporter problem, than hit one of my own bugs Smiley
I think I am good to go!
Have a great day!
One last thing, is the updated code for the Visio Viewer contained in this last download? I want to go through and verify the lines are connecting properly.
Thanks!
Barry
Reply #25 - May 16th, 2008 at 7:34am
Hi Barry,
Yes, this build includes the update for connectors in Visio Viewer.
mclellan
Reply #26 - May 16th, 2008 at 1:24pm
Thanks!
I'll let you know how I make out on my other Visio thread!
Barry
