Normal Topic Background Color in PDF's (Read 1953 times)
mclellan
May 15th, 2008 at 7:28pm
By default the EnableBackground property is set to false for printing your diagrams.
Is it possible to have the PDF Export recognize this value as well?
My background currently uses the default gray background, however I would like my PDF's generated without the background in case they may need to be printed.
Thanks!
Barry
Re: Background Color in PDF's
Reply #1 - May 16th, 2008 at 7:43am
We've added a PdfExporter.EnableBackground property, but won't create a new release build just for this update. Until you get it, you could temporarily set the diagram.BackBrush to a SolidBrush(Color.White) before exporting.
mclellan
Reply #2 - May 16th, 2008 at 1:23pm
Thanks Stoyan!
... will you have the ability to put in a watermark with the next version as well?
Reply #3 - May 16th, 2008 at 1:47pm
We could add an event similar to DrawBackground, say DrawForeground 8) You could handle it to draw a watermark, or what ever else you might need over the diagram items.
mclellan
Reply #4 - May 16th, 2008 at 2:28pm
That would be fantastic!
