Normal Topic Zoom to Cursor (Read 2960 times)
dfmsim
Zoom to Cursor
May 19th, 2008 at 2:21pm
I'm working with version 5.03!
The implemented zoom stretches the diagram to the left and lower side and the cursor is not left on the coordinate in the diagram. Is it possible to implement a Zoom-Function that zooms on a specified coordinate in the diagram? (with all autoscroll,...)
So that the cursor is on the same coordinate all the time!?
The following Code on a Mousewheel-Event works correctly, when the area is scrollable, but not, when there are no scrollbars! Then only the standard zoom behaviour works adequate!
"Diagramview ctl_modelChart;"
Point p=ctl_modelChart.PointToClient(Cursor.Position);
if (!ctl_modelChart.Bounds.Contains(p))
return;
PointF oldcurpos = ctl_modelChart.ClientToDoc(p);
if (e.Delta < 0)
ctl_modelChart.ZoomOut();
else
ctl_modelChart.ZoomIn();
PointF newcurpos = ctl_modelChart.ClientToDoc(ctl_modelChart.PointToClient(Cursor.Position));
float diffx = (oldcurpos.X - newcurpos.X);
float diffy = (oldcurpos.Y - newcurpos.Y);
if (ctl_modelChart.HScrollBar.Visible)
   ctl_modelChart.ScrollX = ctl_modelChart.ScrollX +
     diffx < 0 ? 0 : ctl_modelChart.ScrollX + diffx;
if (ctl_modelChart.VScrollBar.Visible)
ctl_modelChart.ScrollY = ctl_modelChart.ScrollY +
      diffy < 0 ? 0 : ctl_modelChart.ScrollY + diffy;
Re: Zoom to Cursor
Reply #1 - May 20th, 2008 at 5:26am
Ok, we will enable changing the Scroll properties when the diagram area is smaller than the view; then your code should work when there are no scrollbars too.
dfmsim
Re: Zoom to Cursor
Reply #2 - May 20th, 2008 at 6:49am
Thanks!
