Normal Topic Layout (Tree/Layered) - Level/Layer distance (Read 2193 times)
dku
Jun 12th, 2008 at 4:37pm
It is possible in the Layout object to set the Level or Layer distance. Should it be possible to give an 'array' of distances, meaning that the separation between first and second could be different than the distance between second and third, etc ...
Bye
Didier
PS : if array not big enough, will used the last defined distance
Re: Layout (Tree/Layered) - Level/Layer distance
Reply #1 - Jun 13th, 2008 at 5:16am
Thank you for this suggestion. That should not be hard to implement. We'll try to do it in the next couple of weeks.
