Normal Topic Features info (Read 2113 times)
srivch
Features info
Jul 7th, 2008 at 11:58pm
I have just started researching for a workflow diagram tool for .Net(Web Control).
The questions that I have about this tools are:
1) Can I save the diagrams to and retrive from XML?
2) In the work flow diagram can I have links to other work flows?
Quick reply is greatly appreciated as I need to recommend a solution asap.
Re: Features info
Reply #1 - Jul 8th, 2008 at 5:38am
Try our ASP.NET component:
https://www.mindfusion.eu/NetDiagramTrial.zip
1) The Diagram's SaveToXml and LoadFromXml methods let you do that.
2) You could handle the NodeClicked event and load another diagram when a specific node is clicked.
