Normal Topic Appointment selection and visibility (Read 2635 times)
bequer
May 19th, 2008 at 8:21pm
I display appointments in TimeTableView mode and I added a "search appointment" feature, based on some user's criteria: I display an appointment list in a grid and the user can select one and click the button "go to appointment". I'm able to select the proper day.
But I'm not able to select the appointment itself ???. And I want to scroll to the appointment start time minus a celltime to have a "blank" area before.
Is there a manner to do it?
Boquer
Re: Appointment selection and visibility
Reply #1 - May 20th, 2008 at 6:14am
Here is a piece of code that can be used to accomplish this:
MindFusion.Scheduling.Item i = calendar1.Schedule.Items[0];
int itemStartCell = (int)(i.StartTime.TimeOfDay.Ticks / calendar1.TimetableSettings.CellTime.Ticks);
calendar1.VScrollPos = Math.Max(0, itemStartCell - 5);
The above code scrolls to the first item in the schedule, leaving 5 empty cells before the actual start cell of the item.
bequer
Reply #2 - May 20th, 2008 at 2:08pm
Hi Meppy,
It works fine for this part, thanks. What can i do about the appointment selection itself?
bequer
Reply #3 - May 21st, 2008 at 6:29am
In order to select an Appointment, add it to the Calendar.ItemSelection object:
calendar.ItemSelection.Add(app);
bequer
Reply #4 - May 31st, 2008 at 12:51pm
Sorry, I'm late to do my follow up.
All works fine with this.
Thank you Meppy
