Normal Topic Timetable -> disable collision-> appointment (Read 2707 times)
quaint
Jun 5th, 2008 at 8:51am
Can I influence the appointment ordering in timetable mode when I disable collisions?
For example:
I have different kinds of appointments, all with a unique priority. I would like to only display the top-priority appointment when two appointments overlap.
Sincerely,
Paul van Iterson
Re: Timetable -> disable collision-> appoint
Reply #1 - Jun 5th, 2008 at 10:59am
There is no built-in way to achieve this. You can however manually check for overlapping appointments and set the Visible property of those with lower priority to false in order to hide them.
quaint
Reply #2 - Jun 5th, 2008 at 11:06am
Thanks, but I need a bit more sofistication than that..
should result in:
So like an aggregation.... I'll work out alternative methods then! Unless you have some more suggestions?
Reply #3 - Jun 5th, 2008 at 12:33pm
Here is a method that can help you achieve the desired functionality:
private void UpdateVisibility()
	calendar1.BeginInit();
	foreach (Item item in calendar1.Schedule.Items)
		item.Visible = true;
		ItemCollection items = calendar1.Schedule.GetAllItems(
			item.StartTime, item.EndTime);
		if (items.Count > 1)
			foreach (Item a in items)
				if (a == item)
					continue;
				if (!a.Visible)
					continue;
				if (a.Priority > item.Priority)
					item.Visible = false;
				if (a.Priority < item.Priority)
					a.Visible = false;
	calendar1.EndInit();
Invoke this method in the ItemCreated, ItemModified and ItemDeleted event handlers in order to update the visibility of the overlapping items.
quaint
Reply #4 - Jun 6th, 2008 at 7:15am
Nice, neat function!
However still doesn't totally match my needs, but is a good starting point though!
What I need is a way to make underlying items (with less priority) PARTIALLY invisible (i.e. only the part that is actually below an overlapping higher-prio item). So that part that isn't overlapped should still be visible!
Thanks tho, this is a good starting point for me! Smiley
