Normal Topic Override appointment paint event (Read 1786 times)
Vilhelms
Jun 19th, 2008 at 8:47pm
Is there an easy way to override the default appointment paint event without having to implement a custom IItemViewer interface? I just want the standard appointment as-is but with a header icon - if I implement IItemViewer I then have to write all the display code from scratch which I do not want.
Re: Override appointment paint event
Reply #1 - Jun 20th, 2008 at 6:27am
You should set the Calendar.CustomDraw property to CalendarItem or ScheduleItem, depending on whether you want to paint an item in Timetable view or in another view. Then you need to handle the Calendar.Draw event and perform any additional item drawing within the event handler.
