Normal Topic MonthRange - current time (Read 1956 times)
BenWTS
Jun 19th, 2008 at 7:14pm
Here is the issue I'm seeing. I added the MonthRange control to my form in April, so the CurrentTime is set to '4/13/2008' in the designer mode.
In the loading of the form I am doing the following:
mfMonthRange.BeginInit();
mfMonthRange.CurrentTime = DateTime.Today;
mfMonthRange.Selection.Set(DateTime.Today);
mfMonthRange.EndInit();
The problem is, although the selection is correctly set to today's date, the month is still displaying April instead of June. You have to actually hit the arrow buttons to scroll it over to June.
What am I doing wrong? Or how can I force it to display the correct month.
Re: MonthRange - current time
Reply #1 - Jun 20th, 2008 at 6:32am
The Calendar.CurrentTime property is only used when the control needs to find out which is the current date in order to paint it with a different color in certain views. It doesn't affect the currently visible set of dates. In order to scroll to a particular date programmatically, use the Calendar.Date property:
mfMonthRange.Date = DateTime.Today;
BenWTS
Reply #2 - Jun 24th, 2008 at 7:13pm
Thanks!
I figured it would end up being something simple like this but for whatever reason I didn't see the .Date property Smiley
And I wasn't seeing it being set in some of the samples I was checking like the "Dual View" sample.
Thanks again that worked fine.
