Normal Topic using UIElement as custom arrowhead? (Read 3477 times)
dn
May 26th, 2008 at 5:11pm
Hi
how can I draw an arbitrary UIElement in place of the normal arrowhead?
the closest thing I can find in the samples is CustomDrawLinks.xaml.cs but all it does it load an XML file
thanks
D.
Re: using UIElement as custom arrowhead?
Reply #1 - May 27th, 2008 at 4:40am
You cannot use UIElements as arrowheads. To enable custom drawing, set DiagramLink.CustomDraw = Additional, and handle the DrawLink event.
dn
Reply #2 - Jun 13th, 2008 at 11:02pm
ok, I have managed to draw my custom UIElement (actually a UserControl) arrowhead shape in the DrawLink event
any suggestions on getting tooltips to work when mousing over? just setting the standard ToolTip property alone isn't enough, I guess the diagram itself is intercepting mouse move and hit testing
for that matter, setting the ToolTip property on a normal DiagramLink doesn't seem to give me a tooltip on mouse over either. Is there a straightforward way to  have a tooltip on a normal link?
the docs have the ToolTip property on the base class DiagramItem so if it worksfor node subclasses, one would hope link subclasses can work too
also I will eventually need to be able to handle click/double-click/right-click on it, any suggestions on how to handle that would be great too
thanks
D.
Reply #3 - Jun 15th, 2008 at 11:53am
The link tooltips should be fixed in this version:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=121240332...
The LinkClicked / LinkDoubleClicked events should be raised when you click on the arrowhead. You could handle them and check whether the mouse pointer is within the arrowhead shape.
