Normal Topic ShapeNode - displaced text (Read 4646 times)
dku
Jun 12th, 2008 at 4:33pm
I saw the topic about texts, but it is mentioning for additional text.
Is that the same for the text or does it give a way to put it above or below the node ? (centered with a max width and such things ...).
Bye
Didier
Re: ShapeNode - displaced text
Reply #1 - Jun 13th, 2008 at 5:11am
You could create a new shape definition whose TextArea is below the Outline. For example
using Shape = MindFusion.Diagramming.Wpf.Shape;
ElementTemplate[] textArea = new ElementTemplate[]
	new LineTemplate(-50, 100, 150, 100),
	new LineTemplate(150, 100, 150, 150),
	new LineTemplate(150, 150, -50, 150),
	new LineTemplate(-50, 150, -50, 100)
Shape textBelow = new Shape(
	Shapes.Rectangle.Outline, // copy the Rectangle outline definition
	null, // no decorations
	textArea,
	FillRule.Nonzero,
	"TextBelow");
ShapeNode node = new ShapeNode(diagram);
node.Shape = textBelow;
node.Text = "put it above or below the node";
diagram.Nodes.Add(node);
dku
Reply #2 - Jun 13th, 2008 at 8:48am
Works fine.
Didier
dku
Reply #3 - Jun 13th, 2008 at 3:20pm
If I've good understood, you define the the text area relative to the 'main' area.
Does it give a way to :
- Define the width or height in absolute ?
- Is it possible to choose where the text is aligned in the text area ?
Bye
Didier
Reply #4 - Jun 15th, 2008 at 10:21am
Yes, the text area is defined as percents of the main area. At this time it is not possible to define it in absolute units, but you could create a second fixed-size node and call AttachTo to use it as a label for the main node. Text alignment is set through the TextFormat property.
dku
Reply #5 - Jun 16th, 2008 at 7:14am
Ok, thanks.
Didier
