Normal Topic DiagramNode subtype + Custom UIElement (Read 2268 times)
JasonB
Jun 16th, 2008 at 9:28pm
Is it possible to use a subtype of DiagramNode with a custom UIElement? Right now I just use a custom UIElement and behind the scenes a DiagramNodeAdapter is created for me; I'd like to be able to use a subtype of  DiagramNode and my custom UIElement.  but DiagramNode.UIElement is read-only. Is there some obvious way that I am missing?
Re: DiagramNode subtype + Custom UIElement
Reply #1 - Jun 17th, 2008 at 4:58am
You could inherit from DiagramNode or a derived class and override the UIElement property to return a custom UIElement. Then you will probably see the visuals for both the custom element and the base class, so you might want to override the Draw method with an empty implementation.
