Hot Topic (More than 10 Replies) NetDiagram 2.0 Java Applet Loading Time (Read 6972 times)
lue
I love NetDiagram!
Jun 23rd, 2008 at 3:15am
Hi all,
the loading time for the java applet is very long (and we can see the java symbol), some browser refreshs helps. This effect is only by using the internet explorer 7.0.
With firefox no problems, seconds after starting the diagram is on screen!
Any ideas?
thanks chris
Re: NetDiagram 2.0 Java Applet Loading Time
Reply #1 - Jun 23rd, 2008 at 10:52am
I can't see much difference when loading the applet on my PC. Do both Firefox and IE use the same Java runtime version on your system? Does the delay happen with an empty chart?
lue
I love NetDiagram!
Reply #2 - Jun 23rd, 2008 at 3:31pm
Java Version 1.6.0_05 is installed on both browsers. We tested newly: The problem is that the java loading completely "hangs" ... The chart is not empty. Is there any possibility to force the loading process?
regards chris
Reply #3 - Jun 23rd, 2008 at 5:24pm
Is there anything shown in the Java console? You can open it from the notification icon in the taskbar.
lue
I love NetDiagram!
Reply #4 - Jun 24th, 2008 at 2:45am
Hi Stoyo,
yes, if the java hangs:
java.lang.NullPointerException
at sun.plugin.AppletViewer.loadJarFiles(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
and after changing the page and loading the applet:
java.lang.InterruptedException
     at java.lang.Object.wait(Native Method)
     at java.lang.Object.wait(Object.java:485)
     at sun.plugin.ClassLoaderInfo.lock(Unknown Source)
regards chris
Reply #5 - Jun 24th, 2008 at 4:10am
I've googled for "at sun.plugin.AppletViewer.loadJarFiles(Unknown Source)" and that seems a common problem with IE7 + the latest Java version Undecided If you are loading any other applets apart from the DiagramView's one, could you check if the exception happens if you remove them? Could you email us your aspx page so that our developer can debug that here? Please also see if there are any parameters specified for the applet viewer in the control panel's Java configuration tool and copy them here.
lue
I love NetDiagram!
Reply #6 - Jun 29th, 2008 at 2:58pm
Hi Stoyan,
it seems that this problem is solved with the newest java version 1.6.0_06
chris
lue
I love NetDiagram!
Reply #7 - Jul 15th, 2008 at 5:24am
Hi Stoyan,
the problems are not solved ... sometimes javaapplet is loading fast, mostly is not loading or loading after open and close the browser, change the pages or so.
We have no error messages, the loading is only hanging ....
it seems, that this problem is only if you use a local webserver f.e. on the developer computer. Installed on a separate webserver (w2003) we cannot reproduce this problem.
i send you the files to the support mail address of a testpage build with codecharge 4 from yessoftware.
thanks and best regards
chris
Reply #8 - Jul 18th, 2008 at 10:32am
Hi Chris,
Could you send us the IIS logs from the local server when the problem happens? We tried to open the project in CodeCharge Studio, but it looks for some .ccs file, could you email it to us too?
lue
I love NetDiagram!
Reply #9 - Jul 19th, 2008 at 4:16am
Hi Stoyan,
please look in the support mails. thanks.
best regards
chris
Reply #10 - Jul 21st, 2008 at 7:18am
Hi Chris,
Are you using the Forms Authentication system to implement login?
lue
I love NetDiagram!
Reply #11 - Jul 21st, 2008 at 9:45am
Hi Stoyan,
yes, we use the CodeCharge internal authentification system with login form
regards chris
Reply #12 - Jul 21st, 2008 at 2:03pm
Hi Chris,
Do you know whether the CodeCharge authentication is based on the ASP.NET's Forms Authentication? I am asking because we still have this problem -
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=119304781...
Somehow the Forms Authentication mechanism modifies the HTTP responses returned by the server, the Java plugin does not recognize them, and is not able to load the .jar file. If the CodeCharge login system works in a similar way, try to exclude JDiagram.jar from the authentication system, so it is always unprotected.
lue
I love NetDiagram!
Reply #13 - Jul 22nd, 2008 at 12:25pm
Hi Stoyan,
thanks for your help. It seems that the problems are caused by the authentication. We build a startpage with a mini diagram opening before the login was done.
The first tests are positiv. If we load the java applet before login we have no problems with loading later other diagrams.
we hope this is the solution.
Best regards
Chris
