Hot Topic (More than 10 Replies) static pages embed (Read 4888 times)
parapara
susan
static pages embed
Jul 15th, 2008 at 10:04am
HI~
I would like to be embedded into shapnode static pages, How do ?
The development language is c#.
Tools is netdiagram.
Re: static pages embed
Reply #1 - Jul 15th, 2008 at 11:10am
Do you mean you want to display another web page inside a ShapeNode?
parapara
susan
Reply #2 - Jul 16th, 2008 at 1:14am
Yes, you are right .Smiley
sorry,my English is very poor Embarrassed
parapara
susan
Reply #3 - Jul 16th, 2008 at 10:01am
shapnode.ToolTip="<html><img src='file:d:\\2.gif'</html>";the code is right.
shapnode.ToolTip="<html><iframe src='file:d:\\2.htm'</html>";the code is wrong.
How to write?
shapnode.Text="<html><img src='file:d:\\2.gif'</html>"; the code is wrong.why?
Reply #4 - Jul 16th, 2008 at 10:04am
Smiley Well, unfortunately that's not possible. If you are using ImageMap mode, we could implement some method that would display an IFrame element over a node, which should look as if the node embeds an HTML page. If you need this just for text formatting, check the EnableStyledText topic in the help file.
Reply #5 - Jul 16th, 2008 at 10:18am
The HTML tooltips are a feature of Java Swing, but they do not support IFrames. The Text property could contain only some simple formatting tags, such as <b>,<i>,<color>. Set EnableStylesText = true to enable this.
parapara
susan
Reply #6 - Jul 17th, 2008 at 1:49am
Stoyo wrote on Jul 16th, 2008 at 10:04am:
SmileyStoyan,thank you so much.
I still have a problem.
How can display an IFrame element over a node in the ImageMap mode?
parapara
susan
Reply #7 - Jul 17th, 2008 at 2:03am
Stoyo wrote on Jul 15th, 2008 at 11:10am:
Hi Stoyan
Can i  display another web page inside a  DiagramNode?
Reply #8 - Jul 17th, 2008 at 7:45am
It's not possible right now, we'll implement some way to do that in the 2.0.2 release.
parapara
susan
Reply #9 - Jul 23rd, 2008 at 3:16am
When the version  2.0.2 release, please let me know,thank you !
Reply #10 - Jul 23rd, 2008 at 8:17am
End of August.
