Normal Topic TableNode without Caption (Read 2243 times)
SeppiK
Jun 30th, 2008 at 8:28am
Hello, I have the following Problem:
I use TableNodes in my diagram.
Can I draw TableNodes without captions?
I whould be satisfied if I can disable the seperator between caption and body.
Greetings
Re: TableNode without Caption
Reply #1 - Jun 30th, 2008 at 9:07am
Set CaptionHeight = 0 and Caption = "".
SeppiK
Reply #2 - Jun 30th, 2008 at 9:22am
your recommendation doesn´t help.
The Separator is still visible.
SeppiK
Reply #3 - Jun 30th, 2008 at 10:55am
Hey, now it works?
It was my error.
Thx for support.
greetings
Reply #4 - Jun 30th, 2008 at 11:06am
cool 8)
SeppiK
Reply #5 - Jul 1st, 2008 at 10:27am
Hello again,
Now I have two question.
Is it possible to use an image and text in caption of a TableNode?
When not, can I draw the line only from the first row? Because then it looks like a caption, and I can use all properties of tables to design my custom  "Pseudo" Caption.
Greetz Seppi
Reply #6 - Jul 1st, 2008 at 12:44pm
Set TableNode.ImageAlign to one of the Top* values and the TableNode.Image should appear in the caption area as long as it is small enough. The text is set through the Caption property.
You might set the ColumnSpan of the first cell on the first row to be equal to TableNode.ColumnCount. This will let you use the cell properties to customize the appearance of the whole row.
