Normal Topic Z-Index in NetDiagram (Read 2124 times)
mwolfaardt
Jul 8th, 2008 at 10:52am
How can i set the Z-index of my shapelistbox and diagramview. If i use this control with ASP.NET and ASP.NET AJAX modal popup, it appears in front of my modal popup.
Re: Z-Index in NetDiagram
Reply #1 - Jul 8th, 2008 at 11:26am
Java applets are rendered in their own window and other html elements on the page cannot be rendered over them. I suppose you could use window.open to display some sort of a dialog window over the diagram view.
dhoult
Reply #2 - Jul 27th, 2008 at 12:48pm
just make sure your model dialog appears after the diagram object in the DOM.
Try adding it just before the closing </body> tag.
