Normal Topic Problem with Overview component (Read 4185 times)
CedricL
Jul 10th, 2008 at 6:57am
We were previously using NetDiagram 1.1 with .Net 2.0.
Now, we migrated our application to use NetDiagram 2.0 with .Net 3.5 framework. We have an issue with Overview component : nothing appears after adding shapes to the Diagram component. The Overview remains empty.
Any suggestion ?
Re: Problem with Overview component
Reply #1 - Jul 10th, 2008 at 7:23am
Have you set the DiagramViewID property of the overview? It should look like this:
<ndiag:DiagramView ID="diagramView" runat="server" Style="left: 0px; width: 480px;
    position: absolute; top: 0px; height: 480px" />
<ndiag:Overview ID="ovw" runat="server" DiagramViewID="diagramView" Style="left: 480px; width: 160px;
    position: absolute; top: 320px; height: 160px" />
CedricL
Reply #2 - Jul 10th, 2008 at 7:25am
Yes I set the DiagramViewID property.
Reply #3 - Jul 10th, 2008 at 7:33am
Are you using the Overview control from Diagramming.WebForms.dll? Overview is no longer defined in a separate dll as in the 1.x versions, and the control from the V1 overview.dll won't work with DiagramView.
CedricL
Reply #4 - Jul 10th, 2008 at 7:51am
Yes I use Overview control from Diagramming.WebForms.dll.
I test the FlowCharter sample, with assembly for .Net 3.5 and overview works.
So I will make tests to see if Telerik components and MS Webparts we are using in our application could be the problem.
CedricL
Reply #5 - Jul 10th, 2008 at 8:09am
Ok, I reproduce my issue with your working sample : if Overview component is used as a Webpart and so, contained into a webpartzone, it did not work.
Reply #6 - Jul 14th, 2008 at 1:09pm
Overview used as a webpart worked fine in our test, but the problem you described happens when the DiagramView is a webpart too. We'll try to fix this in the next few days.
Reply #7 - Jul 15th, 2008 at 7:52am
This is fixed now, look in the private messages page for a download link.
CedricL
Reply #8 - Jul 16th, 2008 at 6:46am
Thanks, we will try this fix.
