Normal Topic Arrow connected at one end (Read 1572 times)
koosala
Java Happens
Jul 12th, 2008 at 5:32am
I have the following code. It is a sample to highlight two problems I am facing:
[code]
package goop;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import java.awt.geom.Point2D;
import javax.swing.JApplet;
import com.mindfusion.diagramming.Behavior;
import com.mindfusion.diagramming.Diagram;
import com.mindfusion.diagramming.DiagramAdapter;
import com.mindfusion.diagramming.DiagramLink;
import com.mindfusion.diagramming.DiagramNode;
import com.mindfusion.diagramming.DiagramView;
import com.mindfusion.diagramming.GraphicsUnit;
import com.mindfusion.diagramming.LinkEvent;
import com.mindfusion.diagramming.LinkStyle;
import com.mindfusion.diagramming.NodeEvent;
import com.mindfusion.diagramming.RerouteLinks;
import com.mindfusion.diagramming.ShadowsStyle;
import com.mindfusion.diagramming.ShapeNode;
import com.mindfusion.diagramming.SnapToAnchor;
public class GoopApplet extends JApplet {
private static final long serialVersionUID = 1L;
private Diagram flowChart;
DiagramView flowchartView;
@Override
public void init() {
super.init();
flowChart = new Diagram();
flowchartView = new DiagramView(flowChart);
flowChart.setSelectionOnTop(false);
flowChart.setShadowsStyle(ShadowsStyle.None);
this.getContentPane().add(flowchartView);
flowChart.setMeasureUnit(GraphicsUnit.Pixel);
flowChart.setAllowUnconnectedLinks(true);
flowChart.setLinkStyle(LinkStyle.Cascading);
flowChart.setSnapToAnchor(SnapToAnchor.OnCreateOrModify);
flowChart.setRouteLinks(true);
flowChart.getRoutingOptions().setTriggerRerouting(
RerouteLinks.WhileCreating);
flowChart.setLinksSnapToBorders(true);
testArrowDistortion();
DiagramNode one;
private void testArrowDistortion() {
one = new ShapeNode(flowChart);
one.setBounds(206, 237, 75, 125);
flowChart.add(one);
DiagramLink arrow = new DiagramLink(flowChart, one, new Point2D.Float(
0, 0));
arrow.setAutoRoute(false);
arrow.setStyle(LinkStyle.Polyline);
arrow.setSegmentCount(3);
arrow.getControlPoints().set(0, new Point2D.Float(257, 237));
arrow.getControlPoints().set(1, new Point2D.Float(257, 207));
arrow.getControlPoints().set(2, new Point2D.Float(481, 207));
arrow.getControlPoints().set(3, new Point2D.Float(481, 330));
arrow.setSnapToNodeBorder(true);
flowChart.add(arrow);
flowchartView.addMouseListener(new MouseAdapter() {
@Override
public void mouseClicked(MouseEvent e) {
if (e.getButton() == MouseEvent.BUTTON3) {
one.setBounds(200, 200, 75, 125);
super.mouseClicked(e);
//flowChart.addDiagramListener(new DiagramAdapter() {
//@Override
//public void nodeModified(NodeEvent e) {
//e.getNode().getOutgoingLinks().get(0).setStyle(
//LinkStyle.Cascading);
//super.nodeModified(e);
[/code]
There is one ShapeNode on the FlowChart and one DiagramLink connected to it at one end, with another end free.
1. When you right click the flowchart, the second ShapeNode is moved slightly. The arrow connected to it has its auto route set to false. When I programmatically move the ShapeNode, the free end of the arrow jumps to (0, 0).
2. I have also commented out some code that changes the Link style to cascading when the ShapeNode is moved. Then, the arrow jumps right to the top of the FlowChart.
Is there some way I can work around this?
Praveen
Re: Arrow connected at one end
Reply #1 - Jul 15th, 2008 at 11:37am
To fix that, call arrow.updateFromPoints() after setting the point positions.
