Using flowChart.Net 5.0.3 and Visual Studio 2005.
I am programatiaclly creating TableNodes so I can set them up in a preset format.
Using .redimTable() and .Resize() to set the arrangement of rows / columns that I want, and then .Columns.GetAt().Width to set the widths I require.
The next step is to acess the spanning properties of some of the cells so that the middle column is a single span to hold an image.
//Diagram d is already setup and passed in as an argument;
TableNode n1 = d.Factory.CreateTableNode(rect);
n1.RedimTable(3, 3);
n1.Resize(35, 25);
n1.Columns.GetAt(0).Width = 5;
n1.Columns.GetAt(1).Width = 25;
n1.Columns.GetAt(2).Width = 5;
What I want to use is TableNode.Item(col, row) (doc is here:
http://www.mindfusion.eu/onlinehelp/flowchartnet/P_MindFusion_Diagramming_TableN...), so something like:
n1.Item(1,0).ColumnSpan = 3;
so that the middle column is a single span. However, that function is not available. It does not appear in the auto suggestion list, and if I write it anyway, it won't compile, stating that no method with that name can be found.
Any help or usggestions would be hugely appreciated!
xan.
