Normal Topic BringIntoView (Read 4275 times)
matt.s
BringIntoView
Jul 22nd, 2008 at 8:28am
I can't seem to get BringIntoView to work - if the node I want to bring into view is way off to the right the diagram does not display it.
I'm sure this is a problem with my code, which is;
diagram.BringIntoView(node.Bounds);
Any ideas?
Thanks in advance.
Re: BringIntoView
Reply #1 - Jul 22nd, 2008 at 10:40am
Are you using the official 1.0 release? That method wasn't implemented correctly there. It should work in this version:
https://www.mindfusion.eu/_beta/wpfdiag101pre.zip
as long as Diagram.Bounds contains Node.Bounds and the Diagram object is inside a ScrollViewer.
matt.s
Re: BringIntoView
Reply #2 - Jul 23rd, 2008 at 8:16am
I've downloaded this to no avail - it still won't display nodes off screen.
The diagram is contained in a scroll viewer, and diagram.Bounds.Contains(node.Bounds) returns true.
Also this download has a side affect - the grab handles on the nodes are suddenly about 10 times larger than normal.
Matt
Re: BringIntoView
Reply #3 - Jul 23rd, 2008 at 8:52am
Now the default MeasureUnit is WpfPoint, and we have changed all size-related properties to match it. You will have to scale down the AdjustmentHandlesSize property value to fix the handles size.
Re: BringIntoView
Reply #4 - Jul 23rd, 2008 at 9:08am
Regarding BringIntoView, that was my mistake - we have recently implemented a ZoomToRect method, and I confused it with BringIntoView when you mentioned it. The BringIntoView(Rect) method you are using is implemented by the base FrameworkElement class, but apparently it does not work correctly for Diagram. We'll override it or implement a BringIntoView(DiagramItem) method (which is available in our Windows Forms control).
