Normal Topic Require content at the Centre of the client (Read 2112 times)
Anshul
Senior Member
Oct 24th, 2009 at 1:57pm
Hi Stoyan,
I have some nodes and links in the diagram.
If I call FitToScreen() function, Contents of the diagram should come in the center of the Client area.
But it is not working as expected.
Please suggest for this as early as possible.
Following is the code which for  FitToScreen().
private void FitToScreen()
           diagram.ZoomToFit();
           if (diagram.ZoomFactor > 100)
               diagram.ZoomFactor = 100;
           Point p1 = scrollViewer.TransformToDescendant(diagram.DocumentPlane).Transform(
                      new Point(0, 0));
           Point p2 = scrollViewer.TransformToDescendant(diagram.DocumentPlane).Transform(
                      new Point(scrollViewer.ActualWidth, scrollViewer.ActualHeight));
           Rect containerRect = new Rect(p1, p2);
           Rect contentRect = diagram.GetContentBounds(false, false);
           double differenceInWidth = containerRect.Width - contentRect.Width;
           double differenceInHeight = containerRect.Height - contentRect.Height;
           Rect diagBounds = diagram.Bounds;
           diagBounds.Union(contentRect);
           diagram.Bounds = diagBounds;
           Point topLeft = new Point(contentRect.X + differenceInWidth / 2, contentRect.Y + differenceInHeight / 2);
           diagram.ScrollTo(diagram.ClientToDoc(topLeft));
Anshul.
Anshul
Senior Member
Re: Require content at the Centre of the client
Reply #1 - Oct 26th, 2009 at 6:45am
Hi Stoyan,
Please suggest us for this problem.
Anshul
« Last Edit: Oct 27th, 2009 at 9:39am by Anshul »
Anshul
Senior Member
Reply #2 - Oct 28th, 2009 at 8:43am
Hi Stoyan,
Any pointer for the above problem?
Anshul
Reply #3 - Oct 28th, 2009 at 8:49am
One problem I can see is that topLeft is already in document coordinates, so you shouldn't call ClientToDoc on it when calling the scroll method.
Anshul
Senior Member
Reply #4 - Nov 12th, 2009 at 3:00pm
I have tried this but its not working. Any more suggestion?
Anshul
