Normal Topic Tree Layout (Read 1251 times)
digit
Tree Layout
Jul 23rd, 2008 at 10:29pm
I currently use the following code to layout nodes in a tree:
treeLayout = New TreeLayout
treeLayout.LinkStyle = TreeLayoutLinkType.Cascading3
treeLayout.Root = Me.startNode
treeLayout.Direction = TreeLayoutDirection.LeftToRight
treeLayout.Type = TreeLayoutType.Centered
treeLayout.LevelDistance = 10
treeLayout.NodeDistance = 10
This produces a tree looking like this:
We would like the tree layout to look like this:
Is there any way to overide the tree layout or alter the properties to achieve this?
Re: Tree Layout
Reply #1 - Jul 24th, 2008 at 11:02am
Try this:
Dim tl As New TreeLayout()
tl.Direction = TreeLayoutDirection.LeftToRight
tl.LayoutNode = New LayoutNode(AddressOf OnLayoutNode)
tl.LinkStyle = TreeLayoutLinkType.Cascading3
nodes = New List(Of DiagramNode)()
tl.Arrange(Diagram1)
nodes.Reverse()
For Each node As DiagramNode In nodes
	Dim c As RectangleF = RectangleF.Empty
	For Each outg As DiagramLink In node.OutgoingLinks
		Dim child As DiagramNode = outg.Destination
		If (c.IsEmpty) Then
			c = child.Bounds
		Else
			c = RectangleF.Union(c, child.Bounds)
		End If
	Next
	If Not c.IsEmpty Then
		Dim b As RectangleF = node.Bounds
		b.Y = c.Top
		node.Bounds = b
	End If
Next
Private nodes As List(Of DiagramNode)
Private Sub OnLayoutNode(ByVal node As DiagramNode, ByVal r As RectangleF)
	nodes.Add(node)
End Sub
