Normal Topic tablenode.addrow (Read 1773 times)
digit
tablenode.addrow
Jul 24th, 2008 at 1:23am
       'Dim tableNode As TableNode = New         Dim tableNode As TableNode = New TableNode(Diagram)
       tableNode.RedimTable(0, 0)
       Dim rowPosition As Integer = tableNode.AddRow()
       tableNode.Rows(rowPosition).Header = True
       tableNode.Rows(rowPosition).Expanded = True
       tableNode(0, rowPosition).Text = "Conditions"
Bug is on the last line of code - index out of bounds
Re: tablenode.addrow
Reply #1 - Jul 24th, 2008 at 8:53am
You have zero columns in the table, so the exception happens because of the first index, and not from rowPosition. Change the first RedimTable argument to 1 and this should work.
