Normal Topic Layered layout - ordering of sub elements (Read 4473 times)
dku
Jul 24th, 2008 at 5:02pm
I'm using layered layout for a 'near' tree diagram (my element can have several parents, so, not really a tree).
It is working well, but gives it any possibility to sort the elements. When layout n sub-elements for an element, it will be fine if I can determine the order of the sub-elements in the layer (or at least direct it ...)
Do you see any possibilities to do that ?
Didier
Re: Layered layout - ordering of sub elements
Reply #1 - Jul 25th, 2008 at 10:33am
Unfortunately, you cannot control in what order LayeredLayout arranges child nodes. However, you could sort them yourself after applying the layout:
LayeredLayout ll = new LayeredLayout();
ll.Arrange(diagram);
diagram.ResizeToFitItems(10);
foreach (DiagramNode node in diagram.Nodes)
	DiagramNodeCollection childNodes = new DiagramNodeCollection();
	foreach (DiagramLink link in node.OutgoingLinks)
		DiagramNode dest = link.Destination;
		if (Math.Abs(node.Bounds.Bottom + ll.LayerDistance - (dest.Bounds.Y)) < 0.1)
			childNodes.Add(dest);
	ArrayList sortedByX = new ArrayList(childNodes);
	sortedByX.Sort(new XComparer());
	RectangleF[] sortedRects = new RectangleF[childNodes.Count];
	for (int i = 0; i < childNodes.Count; ++i)
		sortedRects[i] = ((DiagramNode)sortedByX[i]).Bounds;
		childNodes[i].Bounds = sortedRects[i];
public class XComparer : IComparer
	public int Compare(object x, object y)
		DiagramNode n1 = x as DiagramNode;
		DiagramNode n2 = y as DiagramNode;
		if (n1.Bounds.X < n2.Bounds.X) return -1;
		if (n1.Bounds.X > n2.Bounds.X) return 1;
		return 0;
That code assumes all nodes have the same height. It will probably create more link crossings, and you might have to provide for more comlex situations, e.g. sorting also by the "grandchild" positions.
dku
Reply #2 - Aug 11th, 2008 at 12:48pm
Thanks. It works, I can sort the nodes.
It gives node crossing with the same parent object. It means that in the Arrange method from layout, you gives a position at the origin of the link.
Gives it a way to tell the diagram to redraw links or a way that they all take the same origin point ?
Below : parent with 3 subnodes sorted
I imagined that the link is bound to th center of the node, so swapping subnode should redraw correctly.
Didier
Reply #3 - Aug 11th, 2008 at 1:02pm
Call DiagramLink.ReassignAnchorPoints for all links after the layout, or set DiagramLink.ControlPoints[0] to the middle point of the related node side.
g.
dku
Reply #4 - Aug 11th, 2008 at 3:56pm
Thanks a lot.
It works perfectly.
Didier
