Normal Topic EmbossEffects Question (Read 1449 times)
tblue
Jul 25th, 2008 at 6:02am
1. set diagram symbol "EnableEmbossEffects = 'true'" and use 'EffectsProvider'.
I tried change the color to 'white' using 'Shape' function.
But In this case, becasue of grey color effect, it failed to change color to white.
Please tell me how to change diagram symbol color to white in this effect condition.
If you can't suggest normal method, I want to know how to use 'r,g,b combination' to resolve thi problem.
2. When I opened diagram once saved, the setting-value was not exsactly same as that saved.
It seemed 'EnableEmbossEffects' value was not saved.
Is there any solution to resovle this problem?
Re: EmbossEffects Question
Reply #1 - Jul 25th, 2008 at 10:51am
1. The emboss effect applies a filter on the entire surface of the node, which causes the node color to appear dimmed. When you set a white color to an embossed node, it looks darker. Currently, this cannot be avoided using the built-in emboss effect. You might try implementing your own IEffectsProvider.GenerateEmboss(Diagram diagram, GraphicsPath path) method that would not change the interior of nodes.
2. This value is not saved in diagram files, but you can restore it to your application's setting after calling LoadFromFile.
