Normal Topic Start & End Orientation (Read 1777 times)
Exo
Aug 12th, 2008 at 2:19pm
Can anyone help me with the following problem.
I am currently evaluating the pro version and am working on using the RoutingOptions class. I have a requirement that from each of my boxes the arrow should both start and end horizontally to make sure the drawing looks good visually. I have the following code setup.
FlowChart1.RouteArrows = True
FlowChart1.RoutingOptions.TriggerRerouting = raWhileCreating + raWhenModified
FlowChart1.RoutingOptions.EndOrientation = soHorizontal
FlowChart1.RoutingOptions.StartOrientation = soHorizontal
FlowChart1.RoutingOptions.Anchoring = ancKeep
FlowChart1.ArrowStyle = asPerpendicular
The problem is that the horizontal routing just does not work properly at the start and end of the arrow. It always tries to draw it vertically for some reason?
Any ideas what I am doing wrong? Is it because I am forcing the arrow to an anchor point?
Re: Start & End Orientation
Reply #1 - Aug 12th, 2008 at 2:33pm
Set FlowChart1.RoutingOptions.NodeVicinityCost = 100. If that doesnt help, please email the saved flowchart to support@mindfusion.eu.
10x
Exo
Reply #2 - Aug 12th, 2008 at 2:42pm
Thanks glavcho that works perfect!  Smiley
