Normal Topic Visio Export Problem (VB6 Application) (Read 3059 times)
frose
Aug 16th, 2007 at 3:18am
I'm having problems getting the visio export to produce a file that Visio 2003 can read - Viso reports an error number 100 when it tries to open the file that's been created.
I'd love to be able get the viso export sample project - referred to in a previous post - but the link's dead. Any chance of uploading it again ?
Re: Visio Export Problem (VB6 Application)
Reply #1 - Aug 16th, 2007 at 6:46am
Here is a VB sample project:
https://mindfusion.org/_samples/visio_test.zip
Exo
Reply #2 - Aug 20th, 2008 at 2:34pm
I am also having a problem getting the Visio export function to work. Does anyone have a VB6 example program that shows this working?
Reply #3 - Aug 20th, 2008 at 2:54pm
Here is the sample again:
https://mindfusion.eu/_samples/visio_test.zip
The FcxVisioExport.vxt file must be available in the current folder or in the application's executable folder, otherwise exporting will fail.
Exo
Reply #4 - Aug 20th, 2008 at 3:06pm
Thanks Stoyan
My problems are solved with the help of this example.
