Normal Topic SetDocSize Example (Read 1515 times)
Exo
SetDocSize Example
Aug 22nd, 2008 at 3:45pm
Can anyone give me a quick example of some VB6 code that will set the size of the diagram area.
I would like to give my users the option of selecting say A4 and then the drawing area will be sized to an A4 sheet.
I just can't seem to work out the correct way of using the SetDocSize property.
Re: SetDocSize Example
Reply #1 - Aug 25th, 2008 at 10:29am
That should do it:
fcx.MeasureUnit = uPoint
Dim A4WidthInMM As Single
Dim A4HeightInMM As Single
Dim A4WidthInPoints As Single
Dim A4HeightInPoints As Single
A4WidthInMM = 210
A4HeightInMM = 297
A4WidthInPoints = A4WidthInMM / 25.4 * 72
A4HeightInPoints = A4HeightInMM / 25.4 * 72
fcx.SetDocSize 0, 0, A4WidthInPoints, A4HeightInPoints
Here MeasureUnit is set to Point, because the A4 size would be hard to calculate in pixels - you would have to consider the graphics adapter's DPI settings.
