Normal Topic MonthRange/Single Month tooltips (Read 2932 times)
BenWTS
Aug 13th, 2008 at 4:27pm
Is there a way to get tooltips when hovering over dates in the MonthRange or SingleMonth view?
We'd like to display some information on how many appointments or how much free time is available on dates in the tooltip for that date.
Re: MonthRange/Single Month tooltips
Reply #1 - Aug 14th, 2008 at 7:17am
You have to set ShowToolTips property of the Calendar object to true. Then, optionally, you can handle the TooltipDisplaying event in order to customize the displayed tooltip, according to the date cell it is being displayed for.
BenWTS
Reply #2 - Aug 14th, 2008 at 1:28pm
I'm missing something then. Here is some simple code, I set the ShowToolTips to true but I don't get any tooltips when hovering over a date.
Form1.cs:
namespace ToolTipTest
    public partial class Form1 : Form
       public Form1()
           InitializeComponent();
Form1.Designer.cs
    partial class Form1
       /// <summary>
       /// Required designer variable.
       /// </summary>
       private System.ComponentModel.IContainer components = null;
       /// <summary>
       /// Clean up any resources being used.
       /// </summary>
       /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
       protected override void Dispose(bool disposing)
           if (disposing && (components != null))
               components.Dispose();
           base.Dispose(disposing);
       #region Windows Form Designer generated code
       /// <summary>
       /// Required method for Designer support - do not modify
       /// the contents of this method with the code editor.
       /// </summary>
       private void InitializeComponent()
           System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(Form1));
           this.mfMonthRange = new MindFusion.Scheduling.WinForms.Calendar();
           ((System.ComponentModel.ISupportInitialize)(this.mfMonthRange)).BeginInit();
           this.SuspendLayout();
           // mfMonthRange
           this.mfMonthRange.CurrentTime = new System.DateTime(2008, 4, 13, 0, 0, 0, 0);
           this.mfMonthRange.CurrentView = MindFusion.Scheduling.WinForms.CalendarView.MonthRange;
           this.mfMonthRange.Date = new System.DateTime(2008, 4, 17, 0, 0, 0, 0);
           this.mfMonthRange.DateTimeFormat = ((System.Globalization.DateTimeFormatInfo)(resources.GetObject("mfMonthRange.Dat
eTimeFormat")));
           this.mfMonthRange.Dock = System.Windows.Forms.DockStyle.Fill;
           this.mfMonthRange.EndDate = new System.DateTime(2008, 8, 27, 0, 0, 0, 0);
           this.mfMonthRange.Location = new System.Drawing.Point(0, 0);
           this.mfMonthRange.MonthRangeSettings.MonthsPerRow = 1;
           this.mfMonthRange.MonthRangeSettings.NumberOfMonths = 1;
           this.mfMonthRange.MonthRangeSettings.ScrollInterval = 1;
           this.mfMonthRange.MonthRangeSettings.VisibleRows = 1;
           this.mfMonthRange.Name = "mfMonthRange";
           this.mfMonthRange.ShowToolTips = true;
           this.mfMonthRange.Size = new System.Drawing.Size(292, 266);
           this.mfMonthRange.TabIndex = 4;
           this.mfMonthRange.Theme = MindFusion.Scheduling.WinForms.ThemeType.Windows2003;
           // Form1
           this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
           this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
           this.ClientSize = new System.Drawing.Size(292, 266);
           this.Controls.Add(this.mfMonthRange);
           this.Icon = ((System.Drawing.Icon)(resources.GetObject("$this.Icon")));
           this.Name = "Form1";
           this.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen;
           this.Text = "ToolTipTest";
           ((System.ComponentModel.ISupportInitialize)(this.mfMonthRange)).EndInit();
           this.ResumeLayout(false);
       #endregion
       private MindFusion.Scheduling.WinForms.Calendar mfMonthRange;
Reply #3 - Aug 14th, 2008 at 2:26pm
It appears that the default value of the tooltip text is an empty string, which does not make the tooltip appear. In order to display a text in the tooltip you will have to handle the TooltipDisplaying event of the Calendar class and set the appropriate text to the Tooltip property of the accompanying event argument.
I checked the documentation about the the ShowToolTips property and found it is incomplete. We'll try to update it for the next release as well as provide some default values for the tooltips to prevent the need to handle the above event.
BenWTS
Reply #4 - Aug 14th, 2008 at 2:48pm
Thanks again, that worked.
