Normal Topic Layered Layout Routing links (Read 1941 times)
fglazenburg
Aug 21st, 2008 at 9:49am
Hey,
I've done some searching on this forum, but couldn't really find an answer to my question, therefore i start a new topic.
I'm currently building a process_flow modeler and I'm using the layered layout. This works out pretty good if i choose to layout the whole diagram. But if i only want to arrange the diagram links, i can't get the same result for the links as when i layout the whole diagram.
Does anybody know how i can arrange only my diagram links in the same way as if i was arranging the whole diagram.
With the orthogoanl layout this is possible, but the orthogonal layout has only cascading links? I use polyline links.
Thanks in advance.
Re: Layered Layout Routing links
Reply #1 - Aug 21st, 2008 at 10:58am
Arranging only the links in LayeredLayout-like style is not possible, and you will have to run the layout for the whole diagram. We have made some optimizations in the LayeredLayout code for the 5.1.1 release and now it might work 2-3 times faster, depending on your diagram size. I can send you our latest build of the flowchart.net assemblies if you'd like to try it.
fglazenburg
Reply #2 - Aug 21st, 2008 at 11:12am
Hey,
Thanks for the fast reply. I did some research myself and found the setting "RoutingOptions.SmartPolylineEnds". If i set this to false, the diagramlinks are routed (by calling diagram.RouteAllLinks) almost the same as with the arrange method.
I'm very interested in the new assemblies. Would you like to send them to me.
Thanks in advance.
Reply #3 - Aug 21st, 2008 at 11:48am
https://mindfusion.eu/_beta/fcnet511.zip
That's a trial version. Drop me an email if you are a client of ours and need the licensed build.
If anyone else is interested in trying this version - it improves the  speed of the following features: LayeredLayout, GridLayout, link routing, styled text (which was pretty slow when processing large texts).
