Normal Topic Progress Indicator on ArrangeDiagram + routing (Read 1401 times)
unisnk
D'Oh!
Sep 4th, 2008 at 9:10am
hi,
I'm still testing the component and I've two questions for you.
1) Since I'm going to manage a large amount of boxes (>100), I want to know if there is a way to obtain a "Progress Indicator" (maybe via Windows' messages?) while the ArrangeDiagram method is executing. This can be useful for the users because the algorithm takes up to 30 seconds to execute. I use ArrangeDiagram on GridLayout and SpringLayout.
2) Sometimes arrows are not routed very well: as you can see in this image, arrow is crossing the box and we have to avoid this. (this happens both to GridLayout and SpringLayout). I was wrong on something?
for SpringLayout I use this:
var lt: SpringLayout;
begin
  lt := CoSpringLayout.Create();
  lt.EnableClusters := true;
  lt.NodeDistance  := 50;
  lt.NumIterations := 500;
  lt.ArrowAnchoring := ancReassign;
  flowchart1.ArrangeDiagram(lt);
end;
this for GridLayout:
var lt: GridLayout;
begin
  lt := CoGridLayout.Create();
  lt.GridSize := 85;
  lt.RandomSeed := 1;
end;
for completeness I also post assigned properties of flowchart1 object
  FlowChart1.RouteArrows := True;
  FlowChart1.ArrowStyle := asPerpendicular;
  FlowChart1.RoutingOptions.Anchoring := ancReAssign;
  FlowChart1.RoutingOptions.NodeVicinityCost := 100;
  FlowChart1.RoutingOptions.CrossingCost := 100;
  FlowChart1.RoutingOptions.NodeVicinitySize := 20;
  FlowChart1.RoutingOptions.TurnCost:= 1;
  flowchart1.RoutingOptions.TriggerRerouting := raWhenIntersectNode;
any suggestions? Thanks in advance. Best Regards
Re: Progress Indicator on ArrangeDiagram + routing
Reply #1 - Sep 4th, 2008 at 3:22pm
1) We'll have to add some new event to let you do this.
2. SpringLayout does not route links at all, and I suppose you could get that effect if using anchor points and the cascading link style. Try calling the RouteAllArrows method after applying the layout.
