Normal Topic how to disable the DefaultShape of the diagram (Read 3550 times)
newUser
Sep 8th, 2008 at 10:48am
sir,thanx for solving my previous problem.I want to know how to make the defaultShape property of diagram to null....Diagram..Behavior = Behavior.DoNothing does not create any shape bt at the same time i can't draw links for existing nodes....i want that after d node created with any selected shape as DefaultShape...the DefaultShape property become null...i.e. user is nt able to draw the shape without selecting a shape. i did ,diagramContainer.defaultShape=null; bt this throws an error...plz help me out
thanx n Regards
Re: how to disable the DefaultShape of the diagram
Reply #1 - Sep 8th, 2008 at 11:54am
Set DiagramView.Behavior = DrawLinks and the user will be able to draw links between existing nodes but not to create new nodes.
newUser
Reply #2 - Sep 9th, 2008 at 6:01am
Thanks......ealier i'd used that n it didn't work bt nw it's working absolutely fine....  :)
newUser
Reply #3 - Sep 10th, 2008 at 9:08am
Hi,I am trying to draw a canvas on the diagram area.I wrote :-
diagram .Behavior = Behavior.Custom;
diagram .CustomNodeType = typeof(Canvas);
when a toolbox item canvas is clicked.It allows me to draw a canvas,bt when nt selected the canvas is nt visible n furthur if i try to add another UIElement like button by same method as above:-
diagram .CustomNodeType = typeof(Button);
the canvas doesn't allow the button to b created in it,i.e. i can't add the button as a child of the canvas.
If i drag n drop the button over the canvas it adds the button as a child:-
void thisCanvas_Drop(object sender, DragEventArgs e)
           Canvas currentCanvas = sender as Canvas;
           Button btn = new Button();
           btn.Height = 20;
           btn.Width = 100;
           btn.Content = "Button1";
           currentNodeCreated = btn as UIElement;
           currentCanvas.Children.Add(currentNodeCreated);
bt it does not allow the child button to modify,i.e text/height/widht can't b changed.
can u help me out?
Thanks n Regards
Kavita.
Reply #4 - Sep 11th, 2008 at 8:12am
The canvas is not visible because by default it has a transparent background. You could set the Background property from the NodeCreated event handler.
DiagramNodeAdapter dna = e.Node as DiagramNodeAdapter;
if (dna != null)
	Canvas canvas = dna.UIElement as Canvas;
	if (canvas != null)
		canvas.Background = Brushes.LightGreen;
The Diagram control lets you select and resize only its child objects; this won't work with child objects you add to the canvas.
