(UTC)
Welcome, Guest. Please
Login
or
Register
News:
Board Index
Help
Search
Login
Register
The MindFusion Forums
Flow Diagramming Components
Windows Forms
› cut
(Moderator: Slavcho)
Previous Topic
Next Topic
Pages:
1
[2]
3
Send Topic
Print
cut (Read 12413 times)
th
, 2005
Re: cut
Reply #15 -
Sep 24
th
, 2008 at 7:30am
Look for IconNode.cs in the samples folder and copy the SaveTo and LoadFrom method implementations to your class. Replace the IconNode properties related lines with
writer.Write(comment);
and
comment = reader.ReadString();
balajigcs
th
, 2008
Re: cut
Reply #16 -
Sep 24
th
, 2008 at 9:24am
Hi this is working..
and there is any way to findout the which node we copied.
Thanks & Regards,&&&&Balaji
th
, 2005
Re: cut
Reply #17 -
Sep 24
th
, 2008 at 12:21pm
You could handle the NodePasted event.
balajigcs
th
, 2008
Re: cut
Reply #18 -
Sep 25
th
, 2008 at 5:12am
yes,this is working.. the nodePasted event is raised after Paint operation is over..
but,when I copied the node after that I need to know which node I copied.. There is any possible way to do this..
th
, 2005
Re: cut
Reply #19 -
Sep 25
th
, 2008 at 7:01am
The copied nodes are the ones that are selected when you call the Copy / Cut methods. The selection changes when you paste items, so you should copy the contents of Diagram.Selection.Nodes into a new collection before calling Copy or Cut.
balajigcs
th
, 2008
Re: cut
Reply #20 -
Sep 25
th
, 2008 at 8:07am
How to implement serialization for your custom Collection properties?.. Acutually for string type properties are changing properly only when I am using cut and paste.. but when i am using collection properties it is not working..
can u give me sample code for.. how to serialize and deserialize custon collection properties..
th
, 2005
Re: cut
Reply #21 -
Sep 25
th
, 2008 at 12:55pm
Have you defined your own collection class, or are using Flowchart.NET types such as DiagramNodeCollection?
balajigcs
th
, 2008
Re: cut
Reply #22 -
Sep 25
th
, 2008 at 2:57pm
I am defining my own collection class.. like this way.
LimitCollection limit = new LimitCollection();[Data]
[Category("Limits")]
public LimitCollection Limit
get
return this.limit;
set
this.limit = value;
this.OnPropertyChanged();
the limitcollection class having the properties.. how can we serialize and deserialize the these collecion types..
th
, 2005
Re: cut
Reply #23 -
Sep 25
th
, 2008 at 3:12pm
You could use the BinaryWriter methods to save the number of items in the collection, and then loop over its items and save each piece of data. When loading, read the number of items, resize the collection, and loop to load each piece of data.
Another way to do that is to make your class implement ISerializable, create BinaryFormatter, and use the formatter's Serialize method.
balajigcs
th
, 2008
Re: cut
Reply #24 -
Oct 20
th
, 2008 at 12:04pm
I am copying the two same nodes with different properties..
i am using the ,
methods like that for saving and loading the properties after copy paste operations..
protected override void LoadFrom(System.IO.BinaryReader reader, PersistContext context)
base.LoadFrom(reader, context);
FileStream flStream = new FileStream("Limits.dat",FileMode.Open, FileAccess.Read);
try
BinaryFormatter binFormatter = new BinaryFormatter();
this.Variables = (VariableCollection)binFormatter.Deserialize(flStream);
finally
flStream.Close();
protected override void SaveTo(System.IO.BinaryWriter writer, PersistContext context)
base.SaveTo(writer, context);
FileStream flStream = new FileStream("Limits.dat",FileMode.OpenOrCreate, FileAccess.Write);
try
binFormatter.Serialize(flStream, this.Variables);
finally
flStream.Close();
but,after paste operation i am getting the two nodes with same properties.. means tha nodes with previously setted properties are not coming.. only for one node properties are coming for the both the nodes..
so,please rectify the problem..
th
, 2005
Re: cut
Reply #25 -
Oct 20
th
, 2008 at 12:13pm
If you use FileStreams, you will have to provide distinct file names, otherwise SaveTo overwrites the file created for the first node when called for the second one.
balajigcs
th
, 2008
Re: cut
Reply #26 -
Oct 20
th
, 2008 at 1:20pm
thanks its working when i am using distict files...
but can u help me with simple how can i maintain like with single file.. or any other method do like that..
th
, 2005
Re: cut
Reply #27 -
Oct 20
th
, 2008 at 1:47pm
Try context.SaveObject(Variables) and Variables = context.ReadObject(). It should work as long as your VariableCollection class is [Serializable].
balajigcs
th
, 2008
Re: cut
Reply #28 -
Oct 21
st
, 2008 at 5:04am
hi,
In PersistContext.cs class having only SaveObject() methos is there but the ReadObject() methos is not there.. the ReadObject method only in xmlpersistcontext..
so,can u please tell some other way?
th
, 2005
Re: cut
Reply #29 -
Oct 21
st
, 2008 at 8:59am
Sorry, it's called LoadObject.
Pages:
1
[2]
3
Send Topic
Print
Previous Topic
Next Topic
Forum Jump »
Board Index
» 10 most recent Posts
» 10 most recent Topics
General
News
Discussion
News
Feature Suggestions
Windows Forms ««
WPF
Html Canvas & JavaScript
Blazor
ASP.NET MVC
ASP.NET
Java Swing
ActiveX
.NET MAUI and Xamarin
Android
Cocoa Touch
Bug Reports
Scheduling and Gantt Components
News
Feature Suggestions
Windows Forms
WPF
Silverlight
ASP.NET
Html & JavaScript
Java Swing
.NET Compact Framework
Bug Reports
Gauge and Chart Components
News
Feature Suggestions
Windows Forms
WPF
Silverlight
ASP.NET
Java Swing
Xamarin
Bug Reports
Grid and Spreadsheet Components
News
Feature Suggestions
Windows Forms
WPF
Html & JavaScript
Java Swing
Bug Reports
Virtual Keyboard Components
News
Windows Forms
WPF
Avalonia
Java Swing
Html & JavaScript
Bug Reports
MindFusion.Reporting
News
Feature Suggestions
Windows Forms
WPF
Silverlight
Bug Reports
MindFusion.UI controls
Windows Forms
WPF
ASP.NET
Other MindFusion tools
News
Feature Suggestions
Discussion
Bug Reports
Archived Boards
Silverlight
Universal Windows Platform
« Board Index
‹ Board
» Powered by
YaBB 2.6.11
YaBB Forum Software
© 2000-2024. All Rights Reserved.
