Normal Topic Remove handels when mouse leaves diagramView (Read 1446 times)
fglazenburg
Sep 19th, 2008 at 9:51am
Hey,
When the mousecursor leaves the diagramView via a node which is placed on the edge of the diagramView, the handles remain on the diagramnode untill the mousecursor enters the diagramview again (not via the same node, but via empty space in the view).
Is there a way to undo this or a setting which lets the view update itself when the mouse leaves the view.
Thanks in advance!
Re: Remove handels when mouse leaves diagramView
Reply #1 - Sep 19th, 2008 at 11:42am
You might handle the DiagramView.MousLeave event and reset the ModificationStart property to hide the handles:
diagramView.ModificationStart = ModificationStart.SelectedOnly;
diagramView.ModificationStart = ModificationStart.AutoHandles;
diagram.Invalidate();
fglazenburg
Reply #2 - Sep 19th, 2008 at 1:38pm
Works!
Thanks (again!)
