Normal Topic Undo / Redo with gouped Boxes (Read 4702 times)
pofra
Sep 19th, 2008 at 9:30am
i have a problem with redo Action and group's
I have 3 boxes in a group and after a moveto by program, if i move the group by hand its ok, of the main Box the redo ( go to old Position ) change only the position of the main object, the child boxes keeps in place of the moveto action.
what have i done wrong ?
pofra
Re: Undo / Redo with gouped Boxes
Reply #1 - Sep 19th, 2008 at 9:33am
Sorry wrong forum, i use FlowchartX ( 4.1.5 )
Reply #2 - Sep 19th, 2008 at 11:55am
Try to save undo/redo records for each attached box:
fcx.BeginUndoRecord
b.BeginUndoRecord True
For Each c In b.SubordinateGroup.AttachedBoxes
	c.BeginUndoRecord True
Next
b.MoveTo 10, 10
	c.EndUndoRecord
Next
b.EndUndoRecord
fcx.EndUndoRecord
pofra
Reply #3 - Sep 20th, 2008 at 8:29am
Hi Stoyo,
now it works, i broke up the groups, moved the boxes and made the groups new.
I think this ist a forgotten feature of groups ( undo/redo handling ) maybe you can fix this in a future version.
thx
PoFra
pofra
Reply #4 - Sep 20th, 2008 at 9:04am
Hi Stoyo,
there is a similar problem with a group of an arrow with an attached textbox with redo.
Maybe you can give me a tip how i can handle this ?
Reply #5 - Sep 20th, 2008 at 1:19pm
Why would you need to break the group and create it anew, didn't that code work for you? You might turn it into a method that take a flowchart item /arrow or box/ as an argument, iterates its attached nodes and creates undo records for the move operation.
pofra
Reply #6 - Sep 22nd, 2008 at 10:38am
Hi Stoyo,
when i didn't break the groups, the attached boxes are moved twice. And the Redo don't work.
pofra
Reply #7 - Sep 22nd, 2008 at 11:05am
Hi Stoyo,
i changed my code now it works ok.
thx for your advice
Wink Franz
Reply #8 - Sep 22nd, 2008 at 12:51pm
great 8)
