Normal Topic Delete selected items (Read 1915 times)
unisnk
D'Oh!
Sep 24th, 2008 at 10:58am
I've a chart with only boxes and arrows. I want to have a popup menu that enables me to delete all selected item.
I've made this code (in Delphi 2007) but it doesn't work as intended: some selected items are not deleted.
procedure TForm_Main.popDeleteSelectionClick(Sender: TObject);
var I: integer;
begin
  for I:=0 to flowchart1.SelectedBoxes.count-1 do
    flowchart1.DeleteItem(flowchart1.SelectedBoxes[I]);
  for I:=0 to flowchart1.SelectedArrows.count-1 do
    flowchart1.DeleteItem(flowchart1.SelectedArrows[I]);
end;
Did I something wrong? Or there is some simpler way?
Re: Delete selected items
Reply #1 - Sep 24th, 2008 at 12:25pm
Modify the cycles so that SelectedBoxes and SelectedArrows are iterated in the reversed order, from index = count - 1 down to 0. That's necessary because calling DeleteItem() also removes the item from the Selected__ collection.
unisnk
D'Oh!
Reply #2 - Sep 24th, 2008 at 12:37pm
Great! It works now. Grin
Thank you very much, Stoyan! 8)
