Normal Topic Put Boxes in a container (Read 1886 times)
unisnk
D'Oh!
Sep 25th, 2008 at 1:25pm
another problem. I select some boxes and I want to put them in another container box.
This code doesn't work (only creates the box b1), but I'm able after executing it to put (manually) all boxes in the newly created container.
procedure TForm_Main.cmdCreateAndPutInContainerClick(Sender: TObject);
var b1: box;
I: Integer;
begin
  b1 := flowchart1.CreateBox (100, 100, 100, 100);
  for I:=(flowchart1.SelectedBoxes.count)-1 downto 0 do
  begin
    flowchart1.SelectedBoxes[I].PutInContainer(b1);
  end;
end;
any suggestions?
Re: Put Boxes in a container
Reply #1 - Sep 25th, 2008 at 3:26pm
Check the SelectAfterCreate value. If it is enabled, the SelectedBoxes collection will contain just b1 after calling CreateBox.
unisnk
D'Oh!
Reply #2 - Sep 26th, 2008 at 7:47am
Right! Now it works...  Grin
Thank you again  Wink
