Normal Topic Detect unconnected nodes (Read 2709 times)
unisnk
D'Oh!
Oct 1st, 2008 at 9:34am
Look at this image:
Starting from yellow node, I want to delete (or hide) automatically all unconnected nodes (the red ones).
There is a method that given two nodes, returns if they are "connected" or the only way to do this is to implement a graph visit algorithm? (maybe using the "tag" property to mark the connected nodes?)
Thank you!
Re: Detect unconnected nodes
Reply #1 - Oct 1st, 2008 at 12:46pm
This code implements the depth-first search algorithm for finding connected components in a graph. After running it, boxes will have the same Tag value if they are in the same connected component.
Sub FindConnectedComponents()
	Dim setIds() As Integer
	Dim i As Integer, component As Integer
	ReDim setIds(0 To fcx.boxes.Count - 1)
	component = 0
	For i = 0 To fcx.boxes.Count - 1
		fcx.boxes(i).Tag = i
		setIds(i) = -1
	Next i
		If setIds(i) = -1 Then
			TraverseComponent setIds, i, component
			component = component + 1
		End If
	Next i
		fcx.boxes(i).Tag = setIds(i)
	Next i
End Sub
Sub TraverseComponent(setIds() As Integer, node As Integer, component As Integer)
	setIds(node) = component
	Dim a As arrow
	Dim child As box
	For Each a In fcx.boxes(node).OutgoingArrows
		Set child = a.DestinationBox
		If setIds(child.Tag) = -1 Then
			TraverseComponent setIds, child.Tag, component
		End If
	Next a
	For Each a In fcx.boxes(node).IncomingArrows
		Set child = a.OriginBox
		End If
	Next a
End Sub
Private Sub Command1_Click()
	Dim colors(0 To 9)
	colors(0) = vbRed
	colors(1) = vbGreen
	colors(2) = vbBlue
	colors(3) = vbWhite
	colors(4) = vbYellow
	colors(5) = vbRed
	colors(6) = vbGreen
	colors(7) = vbBlue
	colors(8) = vbWhite
	colors(9) = vbYellow
	Dim b As box
	For Each b In fcx.boxes
		b.FillColor = colors(b.Tag)
	Next b
End Sub
unisnk
D'Oh!
Reply #2 - Oct 1st, 2008 at 3:27pm
very good. It tooks a little of time to translate this VB code to delphi but now this is the result:
I don't know if the two red boxes is a bug. Anyway with the "tag" value now I'm able to isolate the unconnected boxes. I'll do some other tests before going on.
Thank you very much!
Reply #3 - Oct 1st, 2008 at 5:22pm
They are not a bug - the colors array contains each color twice. I've employed some copy and paste techniques here Wink Anyway the code that colors the boxes is just for testing, and if the graph contains more than 10 connected components, you will get an index-out-of-bounds exception. So if you intend to do the same in production code, use the modulo operator to convert the component index (in box.Tag) to the color index. Should look something like this in Delphi:
colorIndex := box.Tag mod Length(colors);
