Normal Topic Speed Up the GridLayout Method (Read 4712 times)
unisnk
D'Oh!
Oct 7th, 2008 at 10:05am
There is a way to speed up the GridLayout elaboration?
Currently I use these commands:
procedure GridLayoutArrange;
var gl: GridLayout;
begin
     gl := CoGridLayout.Create();
     gl.GridSize := 80;
     gl.ArrowAnchoring := ancReassign;
     screen.Cursor := crHourGlass;
     flowChartMain.ArrangeDiagram(gl);
     flowChartMain.ZoomToFit;
     flowChartMain.FitDocToObjects(10);
     screen.Cursor := crDefault;
end;
I checked the numiteration property, what can be the best number to have a good result? Or there is a better way to speed up? (Often nodes >500 and arrows>1000)
This can be a good deal while we wait for the new "progress" method.
Thank you.
Re: Speed Up the GridLayout Method
Reply #1 - Oct 7th, 2008 at 12:34pm
Setting StartNode and EndNode could speed it up a bit. Otherwise, setting a smaller NumIterations value is the only way to decrease the algorithm running time. We have recently optimized GridLayout in the .NET version of the control; we'll see if the optimizations can be applied to the ActiveX version too.
unisnk
D'Oh!
Reply #2 - Oct 7th, 2008 at 3:58pm
I show you a real case:
this is a chart drawn taking data from a database and arranged via GridLayout method. It took nearly 5 minutes with default options (probably less with NumIterations := 500).
The problem is that those charts could be significant larger (up to 3000 nodes and 3000 arrows).
Is there a method to implement a similar layout with less time cost?
Also it would be great if GridSize could be divided into "horizontal" and "vertical" so we can differentiate the spacing and draw different type of nodes (ex. rectangles instead of squares).
Any hints?
Reply #3 - Oct 7th, 2008 at 4:17pm
Could you save that flowchart to a file and email it to support@mindfusion.eu for our developer to test with?
unisnk
D'Oh!
Reply #4 - Oct 7th, 2008 at 4:26pm
okay, let me do a prototype without "sensitive" informations and I'll send you via email.
Is it okay if I export it with SaveToFile Method?
thank you very much.  Smiley
Reply #5 - Oct 7th, 2008 at 4:29pm
sure, use SaveToFile.
unisnk
D'Oh!
Reply #6 - Oct 7th, 2008 at 4:46pm
mail sent  8)
Reply #7 - Oct 8th, 2008 at 3:33pm
Click the link at the top of the page to open the PM page. Download the updated dll from there and copy it over the one in your system32 folder. Now each iteration should be a bit faster, and there is a new GridLayout property, RouteArrows, which you can set to false to make the layout even faster. This code arranges the 3000+3000 graph for two and a half minutes and the results are not that bad -
Dim gl As New GridLayout
gl.RouteArrows = False
gl.NumIterations = 20
fcx.ArrangeDiagram gl
unisnk
D'Oh!
Reply #8 - Oct 9th, 2008 at 8:37am
great! there was a significant improvement. For the perfection we wait for the "end of rearrangement" event.
Thank you very much for your support. More questions are coming  Wink
