Hot Topic (More than 10 Replies) Arrow head appearing on centre of node, not edge (Read 6762 times)
matt.s
Oct 13th, 2008 at 12:51pm
We have a strange problem when creating nodes in our diagram. The behaviour on the diagram is set to DrawLinks.
Basically, when we create a node and link it to a second node, the arrow head points to the outer edge of the of the second node, which is the behaviour we desire.
However, if we link two nodes which are very close together (almost on top of each other) the arrow points to the centre of the second node. Ideally we would want this set to the outer edge if possible.
Is there a way we can achieve this?
I can email screenshots if this doesn't make any sense!
Matt
Re: Arrow head appearing on centre of node, not ed
Reply #1 - Oct 13th, 2008 at 2:48pm
This should happen only when the nodes intersect. Are you using ShapeNodes, or some custom node type?
matt.s
Reply #2 - Oct 13th, 2008 at 3:50pm
We are using ShapeNode.
The nodes are intersected when the link is made.
When one of the nodes is pulled away from the first node so they are not intersected the arrow head still points to the middle of the node.
Reply #3 - Oct 14th, 2008 at 9:16am
If you set link.Dynamic = true, the link ends will align to the node edges when you pull the nodes apart.
matt.s
Reply #4 - Oct 14th, 2008 at 9:57am
This is exactly what we are after! - Thanks.
One small question; I've just noticed that we can click on each end of the link and detach it away from the node - this behaviour existed before turning Dynamic on.
Is there any way of preventing the user from dragging the link away?
Matt
Reply #5 - Oct 14th, 2008 at 1:16pm
Set the AllowMoveStart and AllowMoveEnd properties of DiagramLink to false.
matt.s
Reply #6 - Oct 14th, 2008 at 2:44pm
That works a treat!
Thanks for your help.
Paul Eden
Reply #7 - Oct 15th, 2008 at 1:35pm
Seconded - top stuff  Smiley
Paul Eden
IgorS
Reply #8 - Oct 17th, 2008 at 11:02am
Hi, Stoyan.
Please answer one question, seems to be related. What can I do to reattach links to node border (or anchor points) after node resizing? Now arrowheads can appear inside or outside the node after i call ResizeToFitText method. Thanks a lot.
Reply #9 - Oct 17th, 2008 at 12:54pm
Hi Igor,
The links stayed connected to the borders in my test, using ShapeNode.ResizeToFit(KeepRatio). What kind of nodes and links are you using?
IgorS
Reply #10 - Oct 17th, 2008 at 1:16pm
Just simple ShapeNode's (Rectangle) and default links. I use ShapeNode.ResizeToFit(KeepHeight).
IgorS
Reply #11 - Oct 17th, 2008 at 1:39pm
Oh, I found the solution of 2 problems at the same time! Smiley
With simple dummy method:
	  private void ResizeNode(ShapeNode node)
		node.ResizeToFitText(FitSize.KeepHeight);
		node.Resize(node.Bounds.Width + 5, node.Bounds.Height);
i got arrowhead attached to anchors points and "margins" for the node. Smiley
Anyway thanks for reply.
Reply #12 - Oct 17th, 2008 at 1:55pm
So ResizeToFitText(KeepHeight) works incorrectly if it does not align the arrowheads. I'll pass this to our developer.
