Normal Topic blank pdf export (Read 3099 times)
keropi
blank pdf export
Oct 13th, 2008 at 1:29pm
I followed the steps in the turorial to export the diagram, but eveytime i export it, it's a blank pdf?
what could be the cause of this porblem?
Re: blank pdf export
Reply #1 - Oct 13th, 2008 at 2:46pm
Does it work if you run the PdfExporter sample project?
keropi
Reply #2 - Oct 13th, 2008 at 3:03pm
No, i cant even open that solution because it says my VS does not support that project type, but most other one's i was able to open,
any help on that?
Reply #3 - Oct 13th, 2008 at 3:06pm
I think it requires SP1 of VS2005. Do you have it installed?
keropi
Reply #4 - Oct 13th, 2008 at 3:09pm
ya, i have sp1 installed
Reply #5 - Oct 14th, 2008 at 9:13am
That project is supposed to be saved in the web project format originally from VS2003, support for which was removed from VS2005, and added back later with VS2005 SP1. If you can't open it by double-clicking the SLN file, try using File -> Open -> Web Site and fixing any missing reference errors.
