Normal Topic How to use NodeListView control? (Read 3021 times)
chris
Oct 14th, 2008 at 10:19pm
How to use code to add a new shape node with a bitmap and add it to a NodeListView control?
Thanks a lot.
Re: How to use NodeListView control?
Reply #1 - Oct 15th, 2008 at 11:54am
ShapeNode node = new ShapeNode(diagram);
node.Bounds = new Rect(2, 2, 20, 20);
node.Image = some_image;
node.ImageAlign = ImageAlign.Fit;
node.Shape = Shapes.Rectangle;
NodeListView.SetLabel(node, "xx");
nodeListView.Items.Add(node);
chris
Reply #2 - Oct 15th, 2008 at 2:09pm
Thanks.
That's what I need.
IgorS
Reply #3 - Oct 17th, 2008 at 11:19am
By the way. Can NodeListView be horisontal? I tried to put nodes into WrapPanel, but it caused runtime exception...  Thanks.
Reply #4 - Oct 20th, 2008 at 8:32am
Try this:
listView.ItemsPanel = (ItemsPanelTemplate)XamlReader.Load(XmlReader.Create(new StringReader(@"
<ItemsPanelTemplate xmlns='http://schemas.microsoft.com/winfx/2006/xaml/presentation'
xmlns:my='clr-namespace:MindFusion.Diagramming.Wpf;assembly=MindFusion.Diagramming.Wpf'>
<StackPanel Orientation='Horizontal'
VerticalAlignment='Center'
HorizontalAlignment='Center'/>
</ItemsPanelTemplate>")));
or set the item template in xaml Wink
