Normal Topic FlowLayout.Arrange method hangs (Read 2481 times)
tom_w
Swimlanes made our dreams
come true :-)
Oct 20th, 2008 at 4:52pm
Hi there
I'm having a problem with the FlowLayout.Arrange method, it seems to hang in some scenarios.
This issue can be easily recreated using the ProcessLayout example:
    Press Arrange button to put nodes in lanes.
    Delete link from ‘Client Credit OK?’ node to ‘Process task’ node.
    Create link from ‘Accept task’ node to ‘Process task’ node by dragging from ‘Accept task’ node to ‘Process task’ node.
    Execution hangs on the ‘FlowLayout.Arrange(diagram)’ line of the arrangeButton_Click sub in Mainform.
Is this a bug or am I doing something stupid (very possible..)
Tom
Re: FlowLayout.Arrange method hangs
Reply #1 - Oct 21st, 2008 at 1:10pm
Right, that's a bug in our code. Our developer will fix it in the next few days and we'll send you an updated version.
tom_w
come true :-)
Reply #2 - Oct 21st, 2008 at 1:44pm
Thanks Stoyo, that will make our testing a bit more straightforward!
Reply #3 - Oct 23rd, 2008 at 8:25am
This version should fix the problem:
https://mindfusion.eu/_temp/flowlt.zip
It also lets you left-align the groups. To do so, add this code:
rules.NodeRules.VerticalDisconnectedGroupsAlignment = true;
For the next official release we'll probably change the property type to some enum to allow for more types of alignments.
tom_w
come true :-)
Reply #4 - Oct 24th, 2008 at 8:18am
Many thanks, I will try it this morning and report back  Smiley
