Normal Topic Attached node in ContainerNode (Read 1907 times)
chris
Oct 21st, 2008 at 11:00pm
I attached a ShapeNode(with text label) to another ShapeNode(with icon) and drag this whole group to a ContainerNode, I got some problem:
When I tried to collapse the ContainerNode, the ShapeNode with Image is collapsed but the attached node with text label still stayed in the Diagram.
Is is a bug? How can I fix it?
Thanks a lot.
Re: Attached node in ContainerNode
Reply #1 - Oct 22nd, 2008 at 7:17am
After attaching the nodes, set imageNode.SubordinateGroup.FollowMasterContainment = true.
chris
Reply #2 - Oct 22nd, 2008 at 2:30pm
It works fine.
