Normal Topic Need Help Urgent (Read 4002 times)
yangyu
Need Help Urgent
Oct 25th, 2008 at 6:32pm
We recently started to try this product and is using it in ImageMap mode.
I am struggling accessing the getMousePosition() from the client side event of the MouseEnter for a node.
i checked the dom and this method doesn't exist under ImageMap mode.
however the onNodeClick event is fired from onClick(event) of the area in the imageMap. Is there anyway to extend this onclick event? or perhaps anyway to access the html attribute of the areas in the imageMap.
Re: Need Help Urgent
Reply #1 - Oct 27th, 2008 at 10:06am
We haven't implemented the mindfusion.diagramming API in JavaScript yet and the methods you can see in the applet's reference are available only in JavaApplet mode. The only event methods you can use in ImageMap mode are getZIndex and getTag, which should be enough to let you identify the node.
yangyu
Reply #2 - Oct 27th, 2008 at 10:28pm
is there anyway to override the generatehtml function?
i need access to the area elements to add custom javascripts.
Reply #3 - Oct 28th, 2008 at 8:06am
We'll add some new event to let you do that.
yangyu
Reply #4 - Nov 5th, 2008 at 10:58pm
do you know when you will be able to have a new release with these chanages?
Reply #5 - Nov 6th, 2008 at 9:50am
We'll try to add this in the next 2-3 days.
Reply #6 - Nov 9th, 2008 at 2:07pm
https://mindfusion.eu/_temp/netdiag_attr.zip
This version adds a new event called CreatingAreaElement. It lets you define additional attributes for the AREA html element created for an item. Its arguments object contains the following two properties:
DiagramItem Item;
StringDictionary Attributes;
and you could handle it like this:
if (e.Item is ShapeNode)
     e.Attributes["onclick"] = "alert('test')";
