Hot Topic (More than 10 Replies) Soem basic advice (Read 11768 times)
BidMaestro
to learn is to live
Soem basic advice
Oct 31st, 2008 at 3:17am
Hi All
I have looked at the supplied example programs and trawled through this forum and could not find some basic examples of vb.net  code that I would to implement.
The first is zoomtorect. Where an area I select within the clientarea using my mouse is then 'zoomed' to become the new client area.
The second is the ability to centre  on the screen a selected node....expecially when using zoomin/zoomout and keeping the selected note in the centre of the client area.
regards
Doug
Re: Soem basic advice
Reply #1 - Oct 31st, 2008 at 8:11am
You can do this using the DrawShapes behavior by setting a boolean flag when the zoom tool is selected and handling a few events:
private bool zoomToRectTool = true;
private void diagram_InitializeNode(object sender, MindFusion.Diagramming.NodeEventArgs e)
	ShapeNode node = e.Node as ShapeNode;
	if (zoomToRectTool && node != null)
		node.Shape = Shapes.Rectangle;
		node.Pen = new Pen(Color.LightGray, 0);
		node.Brush = new SolidBrush(Color.Transparent);
		node.ShadowColor = Color.Transparent;
		node.Text = "select the area to zoom to";
private void diagram_NodeCreated(object sender, MindFusion.Diagramming.NodeEventArgs e)
		diagramView.ZoomToRect(node.Bounds);
		diagram.Nodes.Remove(node);
Reply #2 - Oct 31st, 2008 at 8:27am
You can handle MouseWheel to zoom into or out from the pointed diagram point like this:
private void diagramView_MouseWheel(object sender, MouseEventArgs e)
	Point p = diagramView.PointToClient(Cursor.Position);
	PointF oldcurpos = diagramView.ClientToDoc(p);
	diagramView.ZoomFactor += e.Delta / 60f;
	PointF newcurpos = diagramView.ClientToDoc(diagramView.PointToClient(Cursor.Position));
	float diffx = (oldcurpos.X - newcurpos.X);
	float diffy = (oldcurpos.Y - newcurpos.Y);
	diagramView.ScrollTo(
		diagramView.ScrollX + diffx < 0 ? 0 : diagramView.ScrollX + diffx,
		diagramView.ScrollY + diffy < 0 ? 0 : diagramView.ScrollY + diffy);
BidMaestro
to learn is to live
Reply #3 - Oct 31st, 2008 at 10:19am
Good evening Stoyo (it is 8:20pm here)
Thank you for the reply, per chance do you have the vb.net equivalent of your code? I do not know C, or C+ or C#
If not, I shall try and convert
regards
Doug
BidMaestro
to learn is to live
Reply #4 - Oct 31st, 2008 at 10:49am
I had a go at converting to C code to VB.net for the screen zoom using the mousewheel and it works...might not be elegant code however here it is.
    Private Sub dvMain_MouseWheel(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles dvMain.MouseWheel
       Dim cursorpos As Drawing.Point
       Dim oldcurposF As Drawing.PointF
       Dim newcurposF As Drawing.PointF
       Dim diffx As Single
       Dim diffy As Single
       cursorpos = dvMain.PointToClient(Cursor.Position)
       oldcurposF = dvMain.ClientToDoc(cursorpos)
       dvMain.ZoomFactor += e.Delta / 60.0F
       newcurposF = dvMain.ClientToDoc(dvMain.PointToClient(Cursor.Position))
       diffx = oldcurposF.X - newcurposF.X
       diffy = oldcurposF.Y - newcurposF.Y
       dvMain.ScrollTo(dvMain.ScrollX + diffx, dvMain.ScrollY + diffy)
    End Sub
Reply #5 - Oct 31st, 2008 at 11:31am
The first two methods should look like this in VB:
Dim zoomToRectTool As Boolean = True
Private Sub Diagram_InitializeNode(ByVal sender As System.Object, ByVal e As NodeEventArgs) Handles diagram.InitializeNode
	Dim node As ShapeNode = CType(e.Node, ShapeNode)
	If (zoomToRectTool And Not node Is Nothing) Then
		node.Pen = New Pen(Color.LightGray, 0)
		node.Brush = New SolidBrush(Color.Transparent)
	End If
End Sub
Private Sub Diagram_NodeCreated(ByVal sender As System.Object, ByVal e As NodeEventArgs) Handles diagram.NodeCreated
	If zoomToRectTool And Not node Is Nothing Then
	End If
End Sub
BidMaestro
to learn is to live
Reply #6 - Oct 31st, 2008 at 1:26pm
Thank you.... code works wonderfully well.
Have a great weekend
Doug
MUDO
Reply #7 - Apr 12th, 2009 at 10:10pm
Hi.
Code works. But what can i do to prevent selection & editing nodes? What I want is to have zoom mouse cursor and allow to user only zoom functionality.
Thx.
...MUDO...
Reply #8 - Apr 13th, 2009 at 8:22am
You could handle NodeSelecting and set e.Cancel = true while in zoom mode, or perhaps set Locked = true for all nodes.
MUDO
Reply #9 - Apr 13th, 2009 at 10:05am
Hi!
It works only when
DiagramView.ModificationStart = ModificationStart.SelectedOnly
What to do in situation
DiagramView.ModificationStart = ModificationStart.AutoHandles
There is only NodeSelected event raised.
Thx.
...MUDO...
Reply #10 - Apr 13th, 2009 at 10:10am
You don't need ModificationStart = AutoHandles in zoom mode right? So, set it to SelectedOnly if that works for you.
deanhully
Reply #11 - Sep 24th, 2009 at 4:08pm
Stoyo - I was trying this code out and it works except if I zoom out (decrease zoom factor) and then select the nodes/links on the diagramview the scrollto values revert to 0 and the nodes/links shift up and to the left (by the scroll amount?).
I created a stripped down project to demonstrate this if that would help.
Dean
[quote author=BidMaestro link=1225423028/0#4 date=1225450177]Stoyo
Dim diffx As Single
Dim diffy As Single
End Sub[/quote]
Reply #12 - Sep 24th, 2009 at 5:36pm
Hi Dean,
The control doesn't allow scrolling past diagram.Bounds, and seems that's enforced when you click on items to select them. You could try setting larger diagram.Bounds value when zooming out and restore it when zooming in. This should let the centering code set ScrollX/Y values smaller than 0 when needed.
deanhully
Reply #13 - Sep 25th, 2009 at 1:42pm
Stoyo - could flesh out some psuedo code on how I might implement your advice?
Dean
Reply #14 - Sep 27th, 2009 at 12:07pm
Hi Dean,
It seems that happens because of AutoScroll: the auto-scrolling function enforces the new scroll position to be inside diagram.Bounds, while the mouse-wheel handler might set the scroll position to be outside Bounds. One way to work around that is to make sure diagram.Bounds contains the new scroll position as shown below.
Private Sub view_MouseWheel(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles view.MouseWheel
	Dim diffx As Single
	Dim diffy As Single
	cursorpos = view.PointToClient(Cursor.Position)
	oldcurposF = view.ClientToDoc(cursorpos)
	view.ZoomFactor += e.Delta / 60.0F
	newcurposF = view.ClientToDoc(view.PointToClient(Cursor.Position))
	Dim scrollPos As New PointF(view.ScrollX + diffx, view.ScrollY + diffy)
	If e.Delta < 0 Then
		' zooming out, make the diagram larger to prevent AutoScroll from jumping to 0,0
		If Not diag.Bounds.Contains(scrollPos) Then
			Dim minX = Math.Min(diag.Bounds.X, scrollPos.X)
			Dim minY = Math.Min(diag.Bounds.Y, scrollPos.Y)
			diag.Bounds = RectangleF.FromLTRB(minX, minY, diag.Bounds.Right, diag.Bounds.Bottom)
		End If
	Else
		' zooming in
		' possibly revert to a smaller Bounds size until the one from 100% zoom is reached
	End If
	view.ScrollTo(scrollPos.X, scrollPos.Y)
End Sub
