Normal Topic SVG Node (Read 3389 times)
muthuhamid
SVG Node
Sep 28th, 2009 at 8:44am
Hi
Am trying to add svg node to my diagram.
Am getting the Index out of range error at following line
msvgNode.Parse("C:\SVG\1.svg")
Could you pls tell me what is the problem?.
Re: SVG Node
Reply #1 - Sep 28th, 2009 at 10:35am
Could you email 1.svg to support@mindfusion.eu?
muthuhamid
Re: SVG Node
Reply #2 - Sep 28th, 2009 at 12:04pm
I sent the 1.SVG
Re: SVG Node
Reply #3 - Sep 28th, 2009 at 2:42pm
It seems our SVG parser does not support SVG Pattern objects yet. We'll implement this for the next release.
muthuhamid
Re: SVG Node
Reply #4 - Sep 28th, 2009 at 3:37pm
Hi
So when can i expect approximately for this issue to be fixed.
Thanks.
Re: SVG Node
Reply #5 - Sep 29th, 2009 at 5:26am
Next month.
